My New Macro
0 Members and 1 Guest are viewing this topic. Read 1393 times.
Wind Chaser
My New Macro
« on: 6 Apr 2010, 12:25 am »
Tamron 90mm F2.8 - 1:1 macro
Hand held (lucky shot) 1/200 - F4.5 - ISO 200
JohnR
Re: My New Macro
« Reply #1 on: 6 Apr 2010, 12:43 am »
Cool - always heard good things about the Tamron 90, altho never used one.
Wind Chaser
Re: My New Macro
« Reply #2 on: 6 Apr 2010, 01:33 am »
When I took that shot the focus motor was constantly making minute adjustments on account of camera shake.  Looks like my tripod come in handy after all.
JohnR
Re: My New Macro
« Reply #3 on: 6 Apr 2010, 01:39 am »
Yep, becomes essential at high magnification. I have done close to 1-1 handheld but only with elbow/arm/camera braced on a rock or something. Let's see more ;)
Wind Chaser
Re: My New Macro
« Reply #4 on: 12 Apr 2010, 01:17 pm »
So the ring light finally arrived.  Truth be told it didn't come with an adapter to fit
the Sigma 17-70 macro and that led to the Tamron 90 macro.  In other words... a
cheap light made in China seemed like a reasonable excuse to buy another lens.
Here it is mounted on the camera.
Note the famous big power amp on the left. :lol:
The control module is powered b 2 AA batteries and also comes with a 3 volt DC
adapter and it does fit onto the hot shoe, but I have it sitting on the floor.
The two images above were done with a Cool Pix lest there be any confusion.
The images below with a Pentax K-x - manual focus mainly at F2.8.
There seems to be a fair bit of CA in some of these images, especially on the dime and around the queen
further down .  Not sure why that is?
Again, these are all manually focused.  I was thinking about getting a Katzeye, but I'm not so sure I need
one...  The light has 48 LEDs, but can be switched to run only 24 either on the left or the right.
« Last Edit: 13 Apr 2010, 01:02 am by Wind Chaser »
Wind Chaser
Re: My New Macro
« Reply #5 on: 12 Apr 2010, 01:36 pm »
I should hasten that the 'halo' especially in the 5 cent piece is the cap
from a bottle of Tea Tree oil that I used as a riser.
Wind Chaser
Re: My New Macro
« Reply #6 on: 4 May 2010, 03:40 am »
For convenience hand held sure beats setting up the tripod, but the result isn't quite a sharp.
