tube int-amp for bedroom system?
0 Members and 1 Guest are viewing this topic. Read 1688 times.
albireo13
« on: 5 Apr 2010, 02:29 pm »
Looking for ideas here, and feedback from happy owners of suce.  Looking for a modest (>10w/ch) tube int-amp for my bedroom system .... easy listening, jazz, classical, etc.  I have an old Marantz receiver for now but want to try tubes.   Used with my iMAC for iTunes, CDs, internet radio, etc.   Thus, I only need 1, maybe two inputs.   So .. priorities are:
* good, clean sound ... also low noise
*attractive
* < $1K
  I'm considering Jolida FX-10, Jolida 102b, or 202b .....
Any other good ideas?
Rob
Mariusz
Re: tube int-amp for bedroom system?
« Reply #1 on: 5 Apr 2010, 02:48 pm »
Glow Audio One
Ming-da makes integrated tube amp with iPod docking station
Decco integrated
I have used Aura Note all-in-one integrated/radio/CDP/USB/flash player but you said that you are looking for tubes.
Mariusz
carusoracer
« Reply #2 on: 5 Apr 2010, 02:55 pm »
Jolida 302b :thumb:  EE MiniMax
bunnyma357
« Reply #3 on: 5 Apr 2010, 02:56 pm »
You might try a used Onix/Melody SP3, great sound for the price and there is a ton of info on the web for tube rolling if you want to try that later. They can generally be found for $400 - $600.
http://www.av123.com//index.php?option=com_virtuemart&page=shop.product_details&flypage=shop.flypage&product_id=180&Itemid=37
Jim C
doug s.
  • makin' music
« Reply #4 on: 5 Apr 2010, 02:58 pm »
http://www.audiogon.com/cgi-bin/cls.pl?intatube&1275005034&/Jolida-FX10-Remote-integrated-
sometimes awailable used for even less; but they go really quick.  you can find a plethora of gear that will work in your price-range; new, used & wintage.  but the one i mentioned, (one you already have your eye on), is cute as well!   :green:
doug s.
roscoeiii
« Reply #5 on: 5 Apr 2010, 03:11 pm »
That remote on the FX-10 will be nice for a bedroom set-up...
