0 Members and 1 Guest are viewing this topic. Read 2815 times.
Opinion: SVS makes a pretty good sub. But if you are hankering for a change consider two Songsubs or one Submersive from Seaton. About the same outlay in cash and the two SOngsubs may be easier to locate due to their smaller footprint and possiblly smooth out the overall response. The Submersive will rattle the drywall for sure but is bigger.
This. Jim can also build a custom Rythmik sub too, even with passive radiators.
Thanks for the comments. I have reached out to Jim and will go from there.
