How long is burn in time for Groneberg Ref. Speaker cable
0 Members and 1 Guest are viewing this topic. Read 1698 times.
tubesrule
How many hours for this cable to sounds its best. Just got a pair, not too crazy about it yet, only 24 hors burn in time. Does it get better? Thanks for any info. :roll: :roll:
lazydays
Re: How long is burn in time for Groneberg Ref. Speaker cable
« Reply #1 on: 5 Apr 2010, 03:23 pm »
about as long as it takes to plug it in and turn the power on
gary
shep
« Reply #2 on: 5 Apr 2010, 04:22 pm »
If it is new, give it 100 hours at the very least. Püt on a cd at night, leave it on repeat say. You can keep the vol.low. Ignore the above answer, he doesn't believe.  :deadhorse: You still may not like it, but that's another issue. PS If you plug a speaker cable in and turn the power on, there's a good chance something bad will happen!
tubesrule
« Reply #3 on: 5 Apr 2010, 05:33 pm »
Thanks i will give it at least 100 hours before i give an opinion. Will give it a chance.
