0 Members and 1 Guest are viewing this topic. Read 4596 times.
The aluminum ones also cool better, though, which sometimes cuts fan noise.
BTW, how much quieter (subjectively) was your case (PC or Xbox) after you lined it w/Dmat?
The aluminum ones also cool better, though, which sometimes cuts fan noise. I think the best thing will be some Dynamat or Brown Bread lining the case. My bro is too much of a cheapskate for the Dynamat, I think, and he isn't as bothered by noise as I am. Still, he has 2 PCs sitting next to each other, so the noise is cumulative.Anyway, I'm thinking the Antec case is also steel (it's too cheap to be aluminum- only $45). Again, it's significantly quieter than his other PC, a 2.8 Gig P4 in a Chenbro Blue XSpider case.
