0 Members and 1 Guest are viewing this topic. Read 2585 times.
Are you looking for NAS (networked i.e. Ethernet) or attached (FireWire/USB)?
I was thinking a NAS for outboard mass storage and back up of the music files to be played from the mac mini on board hard drive program/os. I was under the impression the firewire would be the best path to connect these with.
I think it might be semantics he is after..
Well... just trying to help... no sense spending a lot on the wrong thing
The NAS I use (for backups) is the WD World Edition - http://westerndigital.com/en/products/Products.asp?DriveID=587 - seems to work fine, just shows up in the finder as a remote disk.
Does that work with Time Machine as well? The lacie didn't... so can I assume no with newer NASes?
Hi - if the drive is connected with firewire, then it has to be connected to one of the computers - the mini in your case I assume. This is different from a network drive (NAS) which is not connected to any particular computer, just to the network - basically, it's a small dedicated server all by itself.I'd suggest have each computer have enough local storage for its own use, and use a cheap NAS (non-RAID) for backups only. That's what I do anyway. That way the wireless (limited bandwidth) is not really an issue either.Note that you can always share drives attached to any of the computers. (The always-on ones anyway.)I guess if you had something in mind like a shared iTunes library then it's a bit different.
The shared iTunes library is a feature I am attempting to incorporate as part of this system
