Best way to clean a dirty selector switch?
0 Members and 1 Guest are viewing this topic. Read 1183 times.
Ericus Rex
« on: 27 Mar 2010, 08:03 pm »
I have a selector switch that occasionally drops a channel.  Tapping the knob brings that channel back to life.  I suppose it just needs some cleaning.  What's the best way to go about doing this?  If it makes any difference it is an open switch, not sealed.
gerald porzio
Re: Best way to clean a dirty selector switch?
« Reply #1 on: 27 Mar 2010, 08:37 pm »
So much the better that it's open. Unplug the unit, & remove the case. Spray switch w/ tuner cleaner. I have ELC-PS on hand. Rat Shack has their own probably. Some swear by DeOxit which is priceier. After spraying, work the switch thru all inputs 1/2 a doz. to a doz. times. That should do it. It's pretty wham, bam, thank you mam.
