technic 1200 clone the Audio-Technica AT-LP120-USB turntable and ???
0 Members and 1 Guest are viewing this topic. Read 11088 times.
rudy99
i heard this is a close copy to the tchnic 1200 and much cheaper,,  what other technic 1200 copy's are out there?  and r any of them any good?
thanks
evan1
thanks
I think this has more plastic parts
hotrod
 It may appear to look like a SL1200 and cheaper because it is.The build quality is no where near that of the Technics.Just looking at the weight of each table in the specs tell alot.
 I do not think you would be happy with the AudioTechnica,just save your pennies a little longer and purchase a table you can be happy with for a long time to come.
 Or buy yourself a vintage Idler(Lenco),do some DIY mods and end the search forever.
TheChairGuy
It seems a pretty good clone and there's 250 reviews at Amazon on it  :thumb:
http://www.amazon.com/Audio-Technica-AT-PL120-Professional-Direct-Drive-Turntable/product-reviews/B00012EYNG/ref=cm_cr_pr_recent?ie=UTF8&showViewpoints=0&sortBy=bySubmissionDateDescending
Someone else brought the subject up on AC a year or so ago....and many of the reviews read back then indicated some quality control issues.  But the latest 50 or so from the past year seems like those issues were resolved with the latest units.
If its hollow inside (unlike the Technics SL-1200 which is dense rubber and aluminum tri-ply for a fully damped chassis) you can always fill with $25 of modeling clay to approximate the same result as the Technics SL-1200. Perhaps even better it as rubber is not an ideal compound for damping (it tends to 'sound' overdamped...as when used for a platter mat)
John
rudy99
your probably right, but i checked and the audio technica is only .8 llbs less
and it is looking more and more attractive:)
rudy99
John
that is the best freakin idea,   it does seem to be only .8  llbs less but even so that is smart.  im definitley doing that
3 cheers 4 U Jon!
evan1
When Amazon has them for 119.00 they are even better
edit forgot you were looking at the USB model
