stanton t92
0 Members and 1 Guest are viewing this topic. Read 1213 times.
rudy99
stanton t92
« on: 27 Mar 2010, 11:12 am »
is this table descent or is the tonearm  crappy?   had it not been for the key lock feature on this table i  wouldnt even be bothering, but it looks alrgiht, anyone have experience with these?
  oh and i was leaning toward the st150, but i read its like 35 pounds and x 3 cost. so maybe i dont need all that extra crap, just key lock
thankyou
Charles Calkins
Re: stanton t92
« Reply #1 on: 27 Mar 2010, 02:34 pm »
I've the T 90 USB table. I've used it to transfer Vinyl to my PC. Works fine except it is manual operation only. Very annoying!! Aside from that I like what I hear when I play Vinyl. The T 90 and T 92 look the same to me.
                                              Cheers
                                           Charlie
rudy99
Re: stanton t92
« Reply #2 on: 27 Mar 2010, 03:03 pm »
cool that helps,, and u know i didnt even think of that, so ill have to get off my ass every time its ending?
my auto i currently use dosent stop half the time so i end up manually doing it anyways, but i think the pros outway the cons
thanks for the help bro
