Rythmik Sub question
0 Members and 1 Guest are viewing this topic. Read 2464 times.
Eric
« on: 26 Mar 2010, 05:44 pm »
I am considering purhasing a couple of 12 inch premade Rythmik subs to augment the bass perfomance of my Jag/LFM's. What is the essential difference between the GR drivers and the aluminum drivers. This is a music only system
jtwrace
    • TIPP YouTube Channel
Re: Rythmik Sub question
« Reply #1 on: 26 Mar 2010, 05:45 pm »
Where do you think you need to crossover?
Eric
« Reply #2 on: 26 Mar 2010, 05:52 pm »
The specs on the Jag /FM's are
25-20kHz +3db anechoic, 60-15Khz +1.25db (usable in-room bass response extends cleanly to below 20Hz)
jtwrace
« Reply #3 on: 26 Mar 2010, 05:58 pm »
If my memory serves me correct the main difference between the GR paper cone and Rythmik aluminum cone is the maximum crossover point.  I **think** I remember the paper GR driver being able to go to 200Hz.  With that said, judging from your speaker specs, the aluminum would do you just fine.  I use them and cross at 77Hz with no issues.  I've even crossed at 150Hz and felt it was fine.
rajacat
  • Washington State
« Reply #4 on: 26 Mar 2010, 07:57 pm »
Hmm....anybody know if you could use the 12" ACI sub drivers with the Rythmik servo amp?
-Roy
TomS
« Reply #5 on: 26 Mar 2010, 08:01 pm »
-Roy
There isn't a feedback loop on the ACI driver to feed the servo on the amp.
rajacat
  • Washington State
« Reply #6 on: 26 Mar 2010, 08:20 pm »
Ah yes....too bad. Thanks
I have a custom ACI Titan and was hoping that I could use it with the Rythmik amp without purchasing the driver. I think that I'll keep the Titan as is and go with the OB bass option and the Titan will supplement the OBs.  Eventually I'll convert the Titan to full servo
-Roy
TomS
« Reply #7 on: 26 Mar 2010, 08:39 pm »
-Roy
I've been down that road myself.  I had 2 Titan II LE's and moved to a single GR sealed servo a while back and added two dual GR OB servo's recently.  They've worked out great for me.
rajacat
  • Washington State
« Reply #8 on: 26 Mar 2010, 08:44 pm »
I'd sell the Titan but it has a particularly nice box with 1/2" thick oak veneer. It's very heavy and would be a PITA to sell and ship.
-Roy
TomS
« Reply #9 on: 26 Mar 2010, 08:46 pm »
-Roy
I looked at replacing the driver on the bottom with GR and just using external amp.  It is possible so just a thought.
laserman
  • Ambiguous-Optimist
« Reply #10 on: 26 Mar 2010, 09:32 pm »
You could also look at the Apex plate amp for non-servo use -
http://www.apexjr.com/Apexsenior.htm
Danny used to use their product.
