Question about BDA-1 for James
0 Members and 1 Guest are viewing this topic. Read 1863 times.
bud1451
« on: 21 Mar 2010, 07:14 pm »
I have found a used BDA-1 to buy and I have a few questions:
-can the xlr & rca outputs be use at the same time with out any problems(rca for a set of speakers upstairs & xlr for the main system)
-this dac had some software updates last year, what are the updates?
-Serial # 000066, build date 08 34 rev 3, what does this all mean?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Question about BDA-1 for James
« Reply #1 on: 21 Mar 2010, 07:45 pm »
Hi bud1451,
Yes you can use both outputs at the same time. Contact Mike Picket at Bryston and he will let you know what software changes if any you need.  [email protected]
james
