EM7 power
0 Members and 1 Guest are viewing this topic. Read 1751 times.
VincentH
EM7 power
« on: 21 Mar 2010, 03:24 am »
HI, I have EM7 but do not know if it's 2.5 watts or 5 watts. There is no model number on it. Is there a way to check it ? Thanks
Ericus Rex
Re: EM7 power
« Reply #1 on: 21 Mar 2010, 12:05 pm »
I think it goes as follows:  If you can adjust the bias yourself it's a 5 watter, if it is self-bias then it's a 2.5er.  If I'm wrong I'm sure someone will let us know.
skite30
Re: EM7 power
« Reply #2 on: 21 Mar 2010, 08:16 pm »
You are correct about the bias adjustment, when I open mine up the transformers have 5 watt written on top of them also. Bias is easy to adjust but mine need it done every couple of weeks.
