NS-60SE: Great amp for sensitive, wide dynamic range speakers.
0 Members and 1 Guest are viewing this topic. Read 2477 times.
Niteshade
    • Niteshade Audio
I have another rendition of the NS-60 that is ideal for the Zu Defintion 1.9, MKII and Klipsch RF-83's, plus other sensitive speakers that have a wide dynamic range and good power handling capablities. This special edition NS-60 uses an external DC power supply for all tube filaments, has a comparator drive stage and a anode-output pre-driver circuit. This amp is made for high end speakers that are very efficient, yet have a wide dynamic range capable of absorbing relatively high wattage.
All three speakers are within the 1w=100db range. They work good, but not what I would call great with low wattage amplifiers, such as most SET's. I made this amplifier choice based on a worse case scenario. Worse case meaning highest demand on an amplifier during transient peaks as well as high impact listening sessions. In my own system, I have easily wrung out single digit wattage amps as well as smaller double digit ones. I can tell when transient demands are not being met. I listen at relatively high volumes so everything can be heard. I like to hear the non-musical aspects of music! Breathing, papers being moved, subtle instrument imperfections, a pick sliding on strings and so on.
Operating less sensitive speakers, down to around 88db is not a problem for this amplifier. This is a great amplifier choice for a multitude of listening tastes and compatible with a wide range of equipment.
The NS-60 special edition is priced at $2000.00. Our standard NS-60 is $1600.00.
Please note: Not ALL high efficiency speakers accept power like these three. If they do not, we have other models that will suit those perfectly.
« Last Edit: 22 Apr 2010, 12:13 pm by Niteshade »
Niteshade
    • Niteshade Audio
We are offering a sale:
A Beacon II 6SN7 tube stereo preamplifier with the NS-60SE.
This is a very low noise, high power setup that's great for running a wide variety of speakers and designed for people who HATE noise!  Both units can be made to match! There is no extra charge for matching finishes and hardwood trim if it is desired.
Please email or PM for pricing, options and details. I think you will be surprised at the savings!
