nuforce binding posts
0 Members and 1 Guest are viewing this topic. Read 1602 times.
char1
« on: 17 Mar 2010, 11:16 pm »
Hey Jason,
I have had the 9v2's for awhile, they have been very good with my maggie 1.6's. I have used PAD Anniverssary speaker cable between my maggies and the nuforces V2's. The PAD cables came terminated with spades (for the amp end) and banana plugs for my maggie 1.6's. Can you tell me if the binding posts on the 9v2's  will accept maggie 1.6 banana pins if I just reverse the ends of the cables? I Know, I know just experiment by turning them around.....and see if they fit ...well maybe, I hate to screw things up if they fit physically but somehow they will not work properly electrically.. Thanks for the quick response.
Charlie
rustydoglim
    • www.nuprimeaudio.com
Re: nuforce binding posts
« Reply #1 on: 17 Mar 2010, 11:43 pm »
No idea. My best guess is that it will fit.  Banana plug should be standard size.
revolver
« Reply #2 on: 18 Mar 2010, 09:42 am »
Speaking of nuforce binding posts.  I have broken 2 of the dual binding posts on my nuforce MCH3 SE 7 channel amp.  Does anyone know where I can get some replacements?  Please!!  Apologies for being slightly off topic.
nuforce-casey
« Reply #3 on: 18 Mar 2010, 07:28 pm »
Create a helpdesk ticket and provide your address.
