0 Members and 1 Guest are viewing this topic. Read 8584 times.
Thanks everyone for your responses so far. I'm in a slight dilemma. Currently my TT is on my rack and about a foot from my preamp (Van Alstine T8+ w phono). I just ordered an Ultravalve tube amp from Van Alstine and It was recommended to not put my TT above it due to heat. So if I follow that recommendation, I am going to move my TT off the rack and put the amp in it's place. I could move the amp elsewhere instead. Again, still have a longer run. Issues this causes besides the run, is inconvenience to turn the amp on that will be used daily vs my TT that gets used occasionally.
Hang on a minute. Frank suggests that as a general rule, which is a great rule. If your cartridge is prone to hum, I suggest moving the amp to a distance of 4 feet, by the way the crow fly's. If it's a really well shielded cartridge, then leaving a space of 12" should be more then enough room.If your rack has 3 or 4 shelves in it, I would put the TT on top (obviously), below that on the next shelf, the T8 and below that, the amplifier. If your rack is an open design, there should be plenty of air around each component as to not cause a problem.If you don't have a spot for everything, I'd suggest moving the amp out of the rack, to perhaps a floor standing amp stand. That could be as cheap as an old breadboard with 4 hockey pucks underneath,,,,what ever.Wayner
Mike,I don't like the idea of the Ultravalve right under the turntable, not because of heat, but am concerned about magnetic interference from the Ultravalves 4 transformers. Thanks for the pictures, now I can see what's going on. I like the table right where it is. I assume the component below it is a DAC. I'd put the DAC and the Oppo on the shelf below the TT and stick the Ultravalve on the shelf where the T8 is, and put the T8 where the Oppo is. I don't really think you will have any problems with everything on this rack, unless the Oppo and DAC don't fit on the same shelf, but it does look like they will.Wayner
I'd like to shelf mount my turntable and best place is going to be approximately 15-20 feet from the preamp. Anyone feel this is a bad thing to do due to signal distance over RCA cables?
The best scenario for you at that distance, is to consider installing a phono preamp with balance output in close proximity to your TT, to amplify the small cartridge voltage and sensitivity to hum. (PS Audio GCPH comes to mind, but there are others) Then run nice shielded balanced cables (Belden Star Quad, mic cables, or high-end cables) to your stereo preamplifier. This will give you the best sound and least distortion, hum, and signal loss.
that would be the best scenario, if mike didn't already have a fono stage he wants to use, built into his preamp.
I was addressing his question about a 20' run from a cartridge to a phono preamp.
My offering is the best way to satisfy a long run of a very low output. A 20' run from a cartridge to a phono preamp is not recommended.
