0 Members and 1 Guest are viewing this topic. Read 3409 times.
My first question is will this work at all, and can you make iTunes stream to any selection of these three output devices, or does it have to be one at a time?
My second question is can this all be controlled from the remote application for the iPhone/iPod Touch? I assume that the remote will wake up the iMac if need be (?)
Finally I'm interested to know if the remote control can do volume on iTunes, for non-critical situations.
Well, after a fair amount of mucking about with iTunes, I'm on the way... just a few years later than most One thing I'm finding interesting about the whole ripping/importing process is that I'm rediscovering (and re-cataloguing) what I have in my (CD) collection. That alone is almost starting to look like a good reason to go this route...!
I'd like to be able to listen to the library of music on my Macbook in other areas of the house / deck, and wondered if Airport Express and an Apple Touch would do the trick. The remote rooms would be non-critical listening.
Although it might not affect your applications, there are two scenarios that could dictate your wanting to procure the older Airport Express wireless G (A1084) model instead of the newer wireless N (A1264) model. 1. The newer N model apparently has higher jitter and those who are using the optical S/PDIF output into ESS Sabre based DACs have experienced dropouts. (One user who had this problem with the newer N model did try it with the older G model and had no more dropouts) 2. If you intend to passively combine L & R analog outputs for a mono application, the newer N model is unuseable due to heavy distortion produced. (I experienced this as one of my rooms just has a single mono speaker. Luckily this particular active speaker has two separate buffered line inputs, but I now need to adjust two volume controls to change the volume. This distortion produced by passively combing the L & R supposedly was not a problem with the older G model, but I have not personally cooborated this) Steve
Thanks for great info. Would older unit mean I need to buy used? I wanted to go mono, but assumed not possible. How do you wire unit to get mono signal? Doesn't that mean summing hot for both L & R channels?
Yes, the older G (A1084) is only available used. I used an adapter from Radio Shack (RCA male plug to 1/8" stereo phone female jack - same as using a Y-adapter) to combine the L & R channels and was surprised at the super distorted sound coming out. I then read on a forum that someone who was doing this successfully with the older G model, was now experiencing distortion with his newly acquired N model, just as I did. But as I said, I do not have a G model and cannot personally verify this. Steve
Assuming people like the OP and myself have iTunes & a Mac computer, are there any downsides to going Airport Express and a Touch?
