Audio/Video Gear and Systems
The Vinyl Circle
woodsyi
Need some Step-Up recommendations
0 Members and 1 Guest are viewing this topic. Read 1542 times.
Ericus Rex
16 Mar 2010, 11:47 pm »
Hi Folks,
I'm in need of a good step-up. Here are my requirements: must have multiple gain options and must have front panel loading options and be under 1K (new or used). I will plug this into my pre that has a great MM phono stage. The only model I can think of that satifies my requirements is the Graham Slee Elevator. What else is out there?
Listens2tubes
Have you tweaked today?
Re: Need some Step-Up recommendations
17 Mar 2010, 12:55 am »
I recently picked up a Beard Audio Systems HA-1. It's battery driven, silver wired and was built back in 1981. It has fully adjustable load impediance from 3-200 ohms and gain from 23-40db on the front plate. I have to make up a set of Cardas tonearm wire interconnects with ETI Copper Bullets to insert it in my system. I will post a picture later.
jimdgoulding
Reply #2 on:
17 Mar 2010, 01:11 am »
If
Monolithic
is still around they have that kind of flexibility. I think they were reviewed, favorably, by Enjoy The Music but it may have been someone else. With their partnering outboard power supply I think were around $600 in the 90's.
Ericus Rex
Reply #3 on:
17 Mar 2010, 12:11 pm »
Thanks for the recommendations!
Jim, it looks like the Monolithic is actually a complete phono stage. Am I right on this? My two pres have great phono sections (MM) that I would like to take advantage of. That's why I'm thinking SUT.
Keep 'em coming!
DARTH AUDIO
Reply #4 on:
17 Mar 2010, 02:41 pm »
Not sure if this meets your needs.
http://www.10audio.com/bob's_devices_step_up.htm
The Vinyl Circle
woodsyi
