Smally, Grainy pics. . .fixes?
0 Members and 1 Guest are viewing this topic. Read 1527 times.
pjchappy
« on: 16 Mar 2010, 05:22 pm »
Any tips on improving small, grainy digital pics.  I have about 6 pics taken from my Blackberry from the Clapton concert I went to a couple weeks ago.  For some reason, it took all the pics in a low resolution, even though it was set to high resolution.  At high resolution, it surprisingly takes decent pics.
Anyways, I want to make the pics as good as possible, for posterity's sake.  I don't have any professional programs.  However, I have paint.net, which has a good amount of filters, etc.
Paul
pjchappy
Re: Smally, Grainy pics. . .fixes?
« Reply #1 on: 16 Mar 2010, 06:10 pm »
Thanks!  Will do.
I suggest you remove your e-mail address, so spam-bots don't pick it up.
Paul
drphoto
« Reply #2 on: 16 Mar 2010, 07:11 pm »
Done. thanks Paul
pjchappy
« Reply #3 on: 16 Mar 2010, 07:20 pm »
You could have just edited out the e-mail address instead of deleting the post!  :P
Paul
drphoto
« Reply #4 on: 19 Mar 2010, 03:49 am »
oh well, figured the post was dead anyway. sorry I couldn't help you. just not much to work w/ there.
nathanm
« Reply #5 on: 23 Mar 2010, 04:14 pm »
I can't remember where I saw it, but I think there's technology out there that compiles multiple photographs of a scene into a 3D model.  So you could take all the photos on the web of Eric Clapton and assemble them into a 3D Eric Clapton model, and then pose him in the same angle as your original photo.  Or do what I do and search for the highest quality images and try to pass them off as your own.  So far it has worked flawlessly, and as long as I don't let on my secret to anyone I should be okay.
