FS: Heavily Modded Lite Audio DAC-60
0 Members and 1 Guest are viewing this topic. Read 4210 times.
gitarretyp
« on: 14 Mar 2010, 07:44 pm »
I bought this DAC used with the Pacific Valve mods having already been applied; their "mods" consisted of swapping a handful of caps. I added several, much more extensive and meaningful mods:
1) Sonicap output caps with gen 2 bypasses and Cardas RCAs
2) Re-built the output filter to decrease the load on the DAC chips (greatly decreasing load induced distortion) and applying a less aggressive filter to the signal. The filter is very similar to that used in the Hagerman DAC.
3) Implemented an LED bias on the tubes for increased stability and gain to partially make-up for the decrease gain induced by decreasing the load on the DAC chips
4) Upgraded the tube power supply diodes.
5) Upgraded the tube power supply filter caps to Mundorf MLytics
6) Changed the tube power supply filter to a CLC using a Hammond choke
7) Changed the digital filter chip to slow roll-off mode for smoother top end
Due to mods 2 and 3, the output level of the DAC is somewhat lower than stock, and will only output ~1.2V max RMS compared to the CD standard of 2V. This worked fine in my passively pre-amped system and shouldn't be a problem in most systems.
Included are matched pairs of EH 6922s and gold pin Tesla E88Cs and a pair of tube dampers. I would rate the condition of the DAC as 7/10 due to it having developed a few light scratches from being on my work bench several times.
Asking $550 500 shipped.
« Last Edit: 11 Apr 2010, 05:08 pm by gitarretyp »
gitarretyp
Re: FS: Heavily Modded Lite Audio DAC-60
« Reply #1 on: 4 Apr 2010, 07:08 pm »
Bump.
gitarretyp
« Reply #2 on: 11 Apr 2010, 05:08 pm »
Bump and reduced.
gitarretyp
« Reply #3 on: 18 Apr 2010, 04:57 pm »
Bump.
gitarretyp
« Reply #4 on: 23 May 2010, 05:13 pm »
Still available
TomW16
« Reply #5 on: 3 Jun 2010, 10:43 pm »
I have the Lite DAC-60 too and I am planning to mod it as well although I can't seem to find the time to do it.  I remember a thread a while back about the mods that improve upon this already impressive DAC.
I am just curious as to what DAC replaced it?  Best of luck with the sale.
Thanks.
Tom
hifibuff
« Reply #6 on: 4 Jun 2017, 06:23 am »
Is the DAC still available? I am interested in purchasing it.
gitarretyp
« Reply #7 on: 4 Jun 2017, 07:12 am »
Sorry, I sold the DAC many years ago now.
hifibuff
« Reply #8 on: 4 Jun 2017, 09:33 pm »
Thank you for replying. Do you have any information on the mod  you did to the DAC? I may get a Monarchy NM24 dac, which is the same basic dac with in inclusion of a tube line stage.
I am interested in:
2 ) Re-built the output filter to decrease the load on the DAC chips (greatly decreasing load induced distortion) and applying a less aggressive filter to the signal. The filter is very similar to that used in the Hagerman DAC.
7) Changed the digital filter chip to slow roll-off mode for smoother top end.
Thank you.
