0 Members and 1 Guest are viewing this topic. Read 7567 times.
Question. Is the TT grounded ? The arm ? also check the wires from cart. to arm. Sometimes they loosen and cause hum. Any tubes ? if so replace them and try again. What puzzles me is in MM mode no hum. Good luck.charles
First, the amount of gain on an MC compared to an MM is tremendous. That said, location of your power amp in relation to your turntable is critical, as the transformers in the amp will give off tremendous magnetic fields that may be mistaken for cartridge hum. It's making your cartridge hum, but for other reasons (other then being grounded properly). So, how far away is your power amp?Wayner
The recommended load impedance for the Skala is 100 ohms or higher which translates to using the 100 ohm setting on your preamp. The internal impediance you refer to is used when matching a transfomer (SUT) to the cart.
LUCKEEEE The K&K stuff is awsome!
You might try running a ground wire from your preamp to amp. Sometimes that works.
On the off chance your cables are part of this, try playing around with the layout of the cable from table to phono stage. I get a hum when one of the cables from my VPI arm comes within a few inches of the other -- by repositioning alone, I can cure hum. Failing that, try a power cord like one of the PS Audio line where the ground can be lifted -- not the most elegant solution but it cured a pre/power amp hum for me when nothing otherwise so easily would.Just passing on what worked for me.
