Thread on HW-19?
0 Members and 1 Guest are viewing this topic. Read 1531 times.
WntrMute2
Thread on HW-19?
« on: 14 Mar 2010, 12:08 pm »
Has anyone tried the thread drive tweak instead of the rubber drive belt on their HW-19?  I have a MK-IV with the heavy lead filled platter and thought I might try this but wanted your opinions first.
Thanks, Dave
orthobiz
Re: Thread on HW-19?
« Reply #1 on: 15 Mar 2010, 01:34 am »
I haven't tried but would like to. I've read about the knot but I'm still not sure how to do it or why it would be better than a rubber belt.
Paul
TheChairGuy
« Reply #2 on: 15 Mar 2010, 06:20 pm »
One of these days I'll try a thread drive on The Classic...once I buy a VPS.
I don't think you can do thread drive without one of these.....the speed is gonna be a lot different using thread over o-ring rubber.
Maybe down the road.....  :thumb:
John
thegage
« Reply #3 on: 15 Mar 2010, 11:47 pm »
John
I think you mean SDS? Because the thread is significantly thinner than a rubber belt it can cause a large speed change, so you need the SDS to adjust the speed.
Some people feel thread drive adds more "drive," more PRaT, since it is less flexible than rubber. I have found, however, that thread drive transmits more motor noise through the platter to the cartridge, even on a TNT with the motor isolated on a separate platform. And you can hear the knot "twanging" as it hits the motor pulley. YMMV.
John K.
TheChairGuy
« Reply #4 on: 16 Mar 2010, 03:53 am »
Yup, I meant SDS :duh:
Regards, John
