0 Members and 1 Guest are viewing this topic. Read 4333 times.
Although the connection using a coax cable sounded better, it still did not sound as good as the SB3 directly outputting an analogue signal.
Well you know you get what you paid for. I wonder what the results would have been say using a PS perfect wave or a Bryston or an AVA Dac. Or some other high quality Dac. Cheers Charlie
...It seems Sean Adams and the boys knew what they were doing, and at an excellent price point.
I put up a post about the DacMagic when it first came out, as it looked promising. Wayne at Bolder said he was willing to look under the hood and see what mods could be done. You might want to contact him. A PS upgrade would be the first place to start.
When you use a TOSlink, or any variation of fiber optics for that matter the signal has to be converted 2 more times to/from light along with dealing with db loss from the "impossible to actually clean without the correct fiber polishing and cleaning tools" let alone the mostly plastic fiber whips on the market. Whereas using a coax you're not converting anything, it's a straight digital signal.
Last week, I had the chance to audition the Cambridge DAC on a friend's system fed by a squeezebox receiver, so I thought I'd offer my perspective. I do believe that whanafi did not hear much of a difference in his rig, but wanted to let others know that in at least one other system, the Cambridge offered a terrific improvement over using the Duet itself.
