0 Members and 1 Guest are viewing this topic. Read 3028 times.
I have been ripping to flac for the convenience of using metadata tagging. If I want to put something on the Ipod, I use DBpoweramp Batch converter to Apple Lossless. It does take a few steps but its not that time consuming. You don't need to watch it.
Steve, thats a great idea, I'll do a smart paylist that will work best as I listen via SB now 99% of the time and only use my ipod to control SB. I would have never thought of that...Thank you!
How do you get iTunes to realize that there are new songs in the iTunes directory?
I still don't understand. I have two separate folders, one for FLAC, and one for iTunes. If I batch convert the FLAC files and put them into the iTunes library, how does iTunes know that its library folder has additional songs?
