To double check my setup on Frycleaner speaker wire burnin?
0 Members and 1 Guest are viewing this topic. Read 1873 times.
ABEX
Speaker Cable Burn-in
I have only used the unit to burn in single runs and want to make certain I can use the unit the way I have it setup.
I made up a few RCA's with wires coming out with Alagator clips attached and ID'd as Center Positive(Black) and Shell Negative (Red). I the run the Positive from the source using the center Allegator to the otherside and the Souce Negative to the other RCA Allegator which is soldered to the shell.
I am daisy chaining a few set right now using intermediate connectors between legs.
Hope that was written plainly enough.
TIA,Larry
hagtech
« Reply #1 on: 1 Feb 2004, 06:38 am »
Actually, it's not really clear to me what you did.  But maybe it's just the wine (sochu, in fact, a Korean spirit).
Easiest way is to just run current through the wire.  Short the far end of the speaker cable terminals together.  Now you have a loop.  Then drive near end of speaker cable with + and ground (your black and red) from one RCA jack.
You can do same but using + and - active signals to drive.  Or switch to voltage mode and remove short at far end.
jh :)
