Interconnect Placement Advice
0 Members and 1 Guest are viewing this topic. Read 1226 times.
past_or
« on: 11 Mar 2010, 10:51 pm »
Hi gang!
I need expert opionions on this matter.
I have a Bryston 4Bsst amp, BP26, Marantz SM-11s2 and a phono preamp running to a VPI Scout 2.
I use Monster M1000 interconnects running between amp and preamp, turntable and phono, phono and preamp.
I have Audience AU24 running between SACD and the preamp.
I am purchasing a Harmonic Tech Magic Link 2 and need advice as to placement.
I was considering moving the Audience to the Preamp/amp link and placing the new interconnect in the SACD/preamp link. Am I correct in thinking that source to preamp should have the best interconnect, while the preamp to amp comes second? Would my Audience cable be better suited for the turntable/phono or phono/pre link?
I hope what I have shared makes sense.
Thank you so much for your thoughts!
Shaun.
drummermitchell
Re: Interconnect Placement Advice
« Reply #1 on: 12 Mar 2010, 12:31 am »
I think source.If the lake is polluted it has to go down stream to the rivers and creeks.
That's where she starts at the source.
alexone
« Reply #2 on: 12 Mar 2010, 07:29 am »
Shaun,
i think Drummer is right. but let your personal taste decide...
al.
turkey
« Reply #3 on: 12 Mar 2010, 02:00 pm »
This assumes that the new wire actually performs better. That's not a given.
I think past_or just needs to try the wire in various places and see where he thinks it sounds best. It's going to come down to a completely subjective perception anyway, so why not just cut to the chase?
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
« Reply #4 on: 12 Mar 2010, 04:09 pm »
any chain is as strong as the weakest link. it doesn't really matter where that weakest link is.
