question about remote unit
0 Members and 1 Guest are viewing this topic. Read 2754 times.
elecres
« on: 11 Mar 2010, 03:24 am »
I am trying to get the bent audio remote unit working with the radio shack 276-640 38khz ir reciever.I have no other ir receiver to try unit with . any guidance appreciated in advance.tnx
Vinnie R.
    • http://www.vinnierossi.com
Re: question about remote unit
« Reply #1 on: 12 Mar 2010, 02:40 pm »
Hi elecres,
John Chapman of Bent Audio is current away on vacation.  I believe he'll be back on the 19th of March.
Best regards,
Vinnie
elecres
« Reply #2 on: 15 Mar 2010, 09:13 pm »
Thanks you very much for your reply
John Chapman
    • http://www.bentaudio.com
« Reply #3 on: 18 Mar 2010, 11:18 pm »
Hello!
Thanks Vinnie for posting. I am back now - e-mailed you earlier. Thought I'd post here in case you did not get that.
Send along a link to the unit and I will look at how it might be used.
John
