0 Members and 1 Guest are viewing this topic. Read 4286 times.
ummm.... am I reading correctly? Did you recommend a video projector to someone asking for recommendations for an audio surround sound processor?
A few of us (me included) had the Integra 9.8 (or Onkyo Pro 885 identical twin) and moved on to the Denon 3808 (yes it's an AVR) and found better sonics. The 3808 can be used as a pre/pro by using it's pre outs and eschewing it's internal amps (or use the amps for non-critical stuff like zone 2, etc.).
Tyson, I'm a lover of scotch, too. I find the DEs a bit confusing though. Some of them are fairly good (Laga DE comes to mind), but for most I find the original bottling better. By the way, if you find a G&M Ardbeg 9 yo, buy it. It's fantastic and way better than any current Ardbeg (in my opinion, but I no longer drink Ardbeg because it tastes too much like peat; the G&M has peat but tons of other flavors). I've gone through a ton of bottles in the past year, some not available in the U.S., but I haven't posted on the scotch posting. It also helps to have someone to split bottles with, else it gets too expensive. Most overpriced and not that good: Dewar's Signature. Not worth anywhere near the $200/bottle going price. Best: G&M Ardbeg 9yo; Sazarac 18 yo rye; Thomas Handy rye; several others. Too much peat and not enough flavor: Ardbeg Uigeadail and Corryvreckan (though the Corry is better). Hmmm... Onkyo pre-pro? I'll have to look into that. I find it strange that I can buy any number of receivers, with 5-7 channels of amplification, for under 1k, but when you speak of "processors", the cost skyrockets. Why? The receivers have processors in them, too. I'd buy a receiver, but the 5-7 channels of amplification would do nothing, as I have all the amplifier power I need.
It would be difficult to meet your budget here but check on used Marantz AV8003, loaded with features. Good performance for it's price. The Rotel rsp-1570 had slightly lower MSRP and may be another bet used. I'd love to see how the Emotiva performs. Outlaw was selling Onkyo because their processor wasn't done yet, do they now have one? A friend of mine had one of their older models and it didn't hold up well. He said Outlaw has great customer service but not much concellation if the unit isn't doing it's job.Processors are generally more expensive because of better parts and quality which should yield better sonic performance.Just another .02, I moved from solid state to tubes in a mixed HT/stereo system using tubes for the front L/R. The tubes and solid state did not mix well. To the point I couldn't tolerate it. I immediately devised a way to have a separate two channel system and went with a 5 channel amp for HT. I sold the 3-channel solid state and ended up with a Class V 5-channel. It would be interesting to hear one of the Butler 5-channel tube amps but that seems like a expensive tube change when the time comes.
Interesting. I believe I purchased the predecessor to this Denon, which is the receiver I'll be using in my living room. I've never turned it on, though, because all this time my family room has been construction and I've not had reason to turn it on. I'll look into the Denon. Thanks for the help.
