FS: Atlantis "X" Audio Rack - 4 Maple Butcher Block Shelf - Attractive, Solid
0 Members and 1 Guest are viewing this topic. Read 2788 times.
toobluvr
I have re-configured things and no longer need this.  It is the Atlantis "X" rack -- now discontinued and not available.
Simple yet very solid construction, clean lines.   Each shelf will support over 200 lbs!  It came without shelving and is designed to be used with gear sitting right on the "X" cross members.  There are ball bearings to provide resonance control and energy dissipation between gear and rack.  I added the 1 3/4 inch maple BB shelving cause I think it looks much nicer.  Can be used either way.
I am original owner for 2 years, and as the photos show the condition is excellent.   One shelf has some marks from rubber feet, but your gear will cover it.  I'm sure they will fade with time or can be rubbed out.  Or simply flip it and use the other side.
outside dimensions:      34 high x 22 1/4 wide X 15 1/2 deep
shelf:                        19 3/4 wide X 14 1/2 deep  X  1 3/4 thick
usable headroom:        10 bottom, 8, 8   (ball bearings in place, no shelves)
width between posts:   20 1/4
depth between posts:  12 1/4
weight:                      31 lbs (excluding shelves)
If you have a turntable or other gear bigger than top shelf, no worries it will still fit.  Simply put a bigger shelf right on top of the the vertical posts.  This rack is very solid, rigid and strong.  The shelves are nicely finished.  Stain is Ipswich pine and hand rubbed with several coats of Satin poly.
Includes everything like new:  slider feet,  floor spikes + nuts,  ball bearings,  paperwork,  hex wrench.
It is fully assembled so local pickup only, Metro NYC area,  zip 11561.
$260 with shelves.
$210 without shelves.
My price is firm.  Check AG for what you get at this price.  This is much nicer and more solid.
Thanks for looking.
~ John
« Last Edit: 14 Mar 2010, 04:25 pm by toobluvr »
toobluvr
I should mention that the butcher block shelving is not 100% perfect.  I cut, stripped, sanded and re-finished it myself so it is not up to the level of say Mapleshade or Timbernation.
I did use the rack in my living room so I think it shows well, and I believe most folks will have no problem with the quality.
toobluvr
toobluvr
Forgot to mention -- if you are local, I will deliver a reasonable distance.
toobluvr
I give good........SUPPORT!     8)
gerald porzio
This is really a good deal for someone needing a solid rack.
Bemopti123
Own two of these racks.  Snagged them before they were sold out.  A cheaper version of an Adona rack and extremely inexpensive.   :thumb:
mjosef
Looks solid like a rock, wish I had the money...would be on it like that <snap>.  :thumb:
