B 100 SST2 - P Price
0 Members and 1 Guest are viewing this topic. Read 4088 times.
1ZIP
« on: 9 Mar 2010, 08:18 pm »
James:
What's the price for a B100 SST2 - P with remote.  I looked at Audio Advisor but they just list the prices for the basic unit.  Is the MM stage user installable?
I think it is coming down to either the B100 or the McIntosh MA-6600
  • The Demo is Everything!
    • http://www.bryston.com
Re: B 100 SST2 - P Price
« Reply #1 on: 9 Mar 2010, 08:23 pm »
B-100 SST Integrated 100 watt Stereo --$3,895.00 (Does not include Remote)
MM Phono Moving Magnet Phono Stage (Only) --- ADD $500.00
DA Internal Discret Digital Stage --- ADD $1,200.00
Remote - Add $350.00
james
1ZIP
« Reply #2 on: 9 Mar 2010, 09:39 pm »
Thank you sir!
alexone
« Reply #3 on: 10 Mar 2010, 06:32 am »
James:
1ZIP,
i think that the B100 is not yet SST2? it's still a SST.
al.
1ZIP
« Reply #4 on: 11 Mar 2010, 03:11 am »
I think your right,  I've got squared on the brain!
Stu Pitt
« Reply #5 on: 11 Mar 2010, 04:04 am »
The B100 and Mac MA6600 are excellent integrateds.  I'd be very happy with either one.  They sound pretty different from one another, yet I found both equally musical.  In a perfect world, I'd have a Bryston system and a Mac system each in their own room.
I run a high output MC cartridge - Dynavector 10x5 - with my B60's MM card with noproblems at all.  Just letting you know so you don't feel confined to MM carts.
Soldeed
« Reply #6 on: 11 Mar 2010, 08:02 pm »
My local Bryston dealer ordered a NAD M2 for a customer and auditioned it for awhile in
his own setup.  He was very happy but the integrated amp was not cheap.
1ZIP
« Reply #7 on: 12 Mar 2010, 08:08 pm »
James:
How many, if any, upgrades have there been to the B100 SST since 2006?
« Reply #8 on: 12 Mar 2010, 08:17 pm »
James:
Hi 1ZIP,
None to this point.
james
1ZIP
« Reply #9 on: 13 Mar 2010, 05:58 am »
James;
There is a fair amount of detailed spec's available via the Bryston web site for the BDA but doesn't seem like there is an equivalent amount of info available for the optional DAC's in the B100 or BP26 (chips, rates, etc.).  Is that info available someplace?
« Reply #10 on: 14 Mar 2010, 12:31 pm »
James;
BRYSTON BP26 DAC PHILOSOPHY
One way to understand the Bryston DAC is to follow the flow of a signal from when it gets to the BP-26DA in digital form to when it leaves to drive an amplifier. This article describes both what is important in providing an output signal of the greatest fidelity and how Bryston succeeds in this effort.
The digital signal first arrives at the BP-26DA via an RCA connector in standard SPDIF form. This is the normal digital output from a CD player. There are two SPDIF inputs which are selected by a front panel switch. This digital signal contains data at over 1 million bits per second which requires a bandwidth of 5 to 10 million hertz (cycles per second). At these high frequencies it is very important to maintain the quality of the signal by having the correct termination at the SPDIF inputs. Bryston provides this termination in the best manner using high quality devices call impedance matching transformers. These devices provide the best possible interface to the line under all sorts of signal conditions.
Lesser quality terminations will degrade the signal which will cause increased jitter, for example. Once the digital signal is received in the BP-26DA it goes to a digital interface circuit. In the BP-26DA this function is provide by a Cirrus Logic CS8420. This circuit cleans-up the signal to remove the inaccuracies which were added by the transfer from the signal source (say a CD player) to the BP-26DA. One of the key functions of this circuit is a reduction in digital jitter which was part of the signal which it arrived at the BP-26DA. Jitter is a variation in the timing of the digital signal. Left uncorrected is causes very serious degradation in the ultimate audio output. We’ll see several places where jitter can arise in a DAC processor and how this jitter is either eliminated or better yet, not allowed to arise.
The signal next goes to the up-sampling circuit. This function is provided within the same Cirrus Logic CS8420 described in the previous paragraph. This circuit converts the digital signal from one sample rate and bit depth to another. This process is called up-sampling. In the BP-26DA the sample rate is increased from the 44.1k samples per second sample rate and 16 bits of depth (the CD standard) to 96k samples per second and 24 bits. The new samples are created by a complex mathematical process which develops a new set of data from the existing samples. The added 8 bits are filled with place holder information. This up-sampling process provides a digital signal for later conversion to analog by the actual DAC chip. The up-sampling process doesn’t add any new data to that which came off the CD but it puts the data in a form which can better be used by the DAC as described below.
Many people report improved sound from DAC processors which include this up-sampling process. This many be due to the better processing of the up-sampled signal by the DAC chip. This device was designed for these higher sample rates and bit depths and performs better when they are supplied. There may also be a noise shaping process where noise from the audible spectrum is not being eliminated but it is being shifted up to frequencies above audible limits. An added advantage of this up-sampling process is that a total new clock signal is applied which causes a significant reduction in jitter. Up-sampling can be made to a variety of new sample rates. Bryston has found that while higher sample rates can be used, such as 192 kHz or even 384 kHz, there are penalties in noise, jitter sensitivity and distortion which outweigh any added benefits from these higher rates vs. 96 kHz
The DAC integrated circuit (chip) provides the conversion of the digital signal to the analog domain. The chip used in the BP-26DA is the Crystal CS43122. Due to the requirements of the conversion process, this chip and every other DAC chip, applies a digital filter to the signal before the conversion to analog and an analog filter after the conversion process. Due to the previous up-sampling process these filters have their effects far above the audio range. Without up-sampling, the filters would affect frequencies of 20 kHz or perhaps even lower with associated level and phase changes.
The CS43122 is a hybrid multi-bit delta-sigma DAC. This is a rather tongue-twisting description which essentially means that it is an advanced generation chip which uses several methods to optimize the conversion process. This DAC uses a process similar to the previous up-sampling process where it over-samples 8x times. This again allows for filters which are out of the audible range. The output of this process is a sensitive analog signal. The timing of this process is very closely controlled by a low jitter clock.
In the implementation of the DAC we see some of the real benefits of Bryston expertise. The DAC chip requires a very clean digital power supply if it is to function at its optimum. Noise on the digital supply may cause added jitter, noise and distortion. Incorrect board routing of the digital power supply or ground may introduce digital noise into the analog circuits.
This digital power supply is provided from a separate closely regulated and filtered source. The DAC also requires a high quality analog power source. The analog signal is at its lowest magnitude in and coming out of the DAC so any added noise or distortion will be greatly amplified by later stages. Again a separate, heavily regulated and filtered power supply with carefully routed grounds is provided. This sort of care with the power supplies is one of the reasons for the superior sound of BP-26DA. Here is an example of a potential problem: if a digital trace, signal or power, is routed a layer above or below an analog trace it can induce noise via capacitive coupling. Careful trace routing eliminates these problems and provides the extra dB’s of noise and distortion reduction which separate good from great equipment.
The quality of power in an audiophile class piece of equipment is a key to wonderful performance. The BP-26DA uses an external enclosure for the power transformer and the initial stages of filtering and regulation. This separating of the power transformer from the main electronics reduces the level of induced power line noise, especially 60 Hz and its multiples from the supply. A steel enclosure then helps to make sure that external capacitive, magnetic and EMF noise doesn’t enter sensitive circuits. Additional filtering and regulation then occurs within the BP-26DA.
Once the sensitive analog signal leaves the DAC it is buffered and increased in strength by operational amplifiers (Opamps). These are constructed from discrete devices (transistors, resistors and capacitors) instead of integrated circuits. The use of discrete devices allows the design of a circuit which exactly matches the needs of the DAC and other circuits as implemented in the BP-26DA. Use of integrated circuits always involves comprises since they are designed as general purpose devices. The discrete devices allow Bryston to design and manufacture circuits which exactly meet requirements. Discrete devices allow more powerful outputs from opamps since heat from the output driver transistors is separated from other devices. In an integrated circuit opamp this heat can affect the rest of the circuitry since it is all on one chip. Discrete devices also allow specific matching of important characteristics such as input and output impedances based on the specific in-circuit requirements. Discrete opamps can also be designed to more closely match their power source which again leads to reduced distortion and noise. The discrete devices can be tested very closely to match tolerances and matched against each other when matching is important to obtaining a desired result. Circuits can and are designed to require closely matched devices for optimum performance. Integrated circuits have large numbers of components on one chip and it is not practical to do more than high-level sorting of device characteristics. Bryston does sorting and grading with its DAC chips but can do a much finer level with the discrete devices, which leads to better sound quality.
The signal now leaves the DAC board in the BP-26DA and is introduced in to the remainder of the analog circuitry in the BP-26DA including the laser trimmed ALPS volume control and further high-quality discrete opamps. Touches as small as custom made, gold-plated output jacks, leave no missed opportunities of optimum quality.“
james
1ZIP
« Reply #11 on: 14 Mar 2010, 02:27 pm »
Thanks James;
This is what I needed!.  It would nice to archive this someplace on the Bryston web site.  Of course, unless it already is and I missed it!
« Reply #12 on: 14 Mar 2010, 02:44 pm »
Thanks James;
Its part of the original literature I did on the BP26 so it is a little overstated given your question. :D
james
1ZIP
« Reply #13 on: 15 Mar 2010, 12:44 am »
Well it looks like I've talked myself out of a McIntosh integrated.  Best route seems to be a B 100 SST (maybe a used one) with a DAC and MM stage to replace a B-60 and a 4B ST.  Also upgrade the BP26 with an MM stage.
Laundrew
« Reply #14 on: 15 Mar 2010, 01:52 am »
I auditioned a B100 a little while ago and I was very impressed with its performance :D
Be well...
