Stick... Omega speaker with narrow baffle?
0 Members and 1 Guest are viewing this topic. Read 4744 times.
roymail
  • Roy in TX
« on: 9 Mar 2010, 03:27 am »
Hi Louis,
I'm wondering about the narrow baffle of the new Stick speakers.  How did you get them to smooth out the midrange.  I know that's why you changed the original narrow baffle Omega 3's to the wider design.
Perhaps that's not such an issue using the newer hemp drivers.  I'd love to hear the Sticks.  :wink:
-Roy
Louis O
Re: Stick... Omega speaker with narrow baffle?
« Reply #1 on: 11 Mar 2010, 02:20 am »
Hi Roy,
The midrange is working out very nicely and it has to do with the balance of the overall design. The Stick is tuned differently. The design gives me better output in the low and mid bass and this balances out the rest.
Louis
roymail
  • Roy in TX
« Reply #2 on: 11 Mar 2010, 07:03 pm »
Louis, thanks and hope the Sticks are a big success for you.  :thumb:
Eadron
« Reply #3 on: 12 Mar 2010, 01:45 pm »
I think Louis has made it again!! The Stick is one hell of a speaker!  :drool:
jouni
Louis O
« Reply #4 on: 16 Mar 2010, 01:19 am »
Hi roymail and Jouni,
Many thanks and they are working out very well. Hope to hear what the alnico will do in them.
Louis
roymail
  • Roy in TX
« Reply #5 on: 8 Apr 2010, 07:36 pm »
Louis, are the Sticks a double bass reflex design or TL's considering their reported excellent low end response?  Anyway, would love to hear them.  :thumb:
