0 Members and 1 Guest are viewing this topic. Read 5605 times.
I can only speak to the Squeezebox Duet receiver as I just got one, works great using ipeng, and the Wolfson DAC does an admirable job. Correct me if I'm wrong but the SB Touch doesn't have a DAC correct? And if your planning on using ipeng as your remote wouldn't you do better with just a duet receiver, I may be wrong but what advantage does the SB Touch offer over a Duet or just a Duet receiver even an older classic SB?? Just wondering..
It has a DAC with native reproduction of 24/96, and the beta testers report the sound quality is superior to earlier units, except for the Transporter, to which it is a close second.
It has a DAC and the difference I believe is it can do 24/96
But you can connect it to a DAC using SPDIF, so what's the big need for USB? You can use any DAC with SPDIF input, and I think most new USB DACs these days will accept SPDIF also.
Is that same for same with 16/44.1 material?
