LM3886 with tube preamp section DIY board
0 Members and 1 Guest are viewing this topic. Read 7810 times.
Atlplasma
  • Just off the boat
Re: LM3886 with tube preamp section DIY board
« Reply #1 on: 8 Mar 2010, 01:50 pm »
How do you think this preamp stacks up against the Nelson Pass B-1? I realize that one is solid state and the other tube based.
sts9fan
« Reply #2 on: 8 Mar 2010, 01:56 pm »
Apples to oranges but I would put my money on Pass.
Mariusz
« Reply #3 on: 8 Mar 2010, 04:48 pm »
Blair
if you want to give it a shot.(or anyone else)
I can cover the parts cost.
One requirement tho:
Need to post pics from build and instractions so
 junior DIYers can benefit.
If DAC kit and input selector could be integrated into design EVEN BETTER.
Cheers
Mariusz :thumb:
srb
« Reply #4 on: 8 Mar 2010, 05:43 pm »
Does this board really have an active preamp stage, or is it basically a power amp with a tube input driver to which you would add a passive volume control or a preamp?
Atlplasma
  • Just off the boat
sts9fan
« Reply #6 on: 8 Mar 2010, 08:49 pm »
What's your skill level?  If you are looking for qualitative listening recs I would be surprised if you get any hits.
JoshK
« Reply #7 on: 9 Mar 2010, 03:02 am »
What's the difference, in this case? Usually the only difference between the two is the amount of gain.
srb
« Reply #8 on: 9 Mar 2010, 04:36 am »
Exactly.  So can my active preamp be used with it, or will there be too much gain?
Atlplasma
  • Just off the boat
« Reply #9 on: 9 Mar 2010, 12:05 pm »
Hi. I guess you're right that it's unlikely anyone would have first-hand experience with both boards, but I thought someone with extensive experience could review the ebay photos and draw some conclusions about design and/or build quality.
As for my skill level, it's pretty limited. I can de-solder and use a volt meter and a soldering iron. With the help of some very knowledgeable friends, I was able to restore my father's old Eico ST-70, which was a lot of fun BTW.
sts9fan
« Reply #10 on: 9 Mar 2010, 01:19 pm »
If you want to use your pre why not just go with a chipamp.com, audio sector or Twisted Pear chip amp?
Niteshade
    • Niteshade Audio
« Reply #11 on: 9 Mar 2010, 01:41 pm »
Very nice Tripath board:
http://cgi.ebay.com/2-100W-4-TK2050-Class-D-Audio-Amplifier-Board-improved_W0QQitemZ350326302225QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5191132611
I know what this one sounds like since I own one. You can't beat it for the price! It is very close to Class D Audio's sound, which I really like.
The fan cooler needs to be replaced with a passive one, or just try it without the fan installed. The fan makes a buzzing noise in the speakers. A seperate supply could be made for it. There is hardly any mechanical noise from it. (It's a good fan!)
What is required: A 25+ volt power supply for best performance. I'd recommend as close to 30 volts as possible. It's not bi-polar.
NOTE: Power output @ 8 ohms is around 45 watts per channel. Mine is using a custom 26 volt power supply. You can get more out of it with a supply doing 30 volts.
NOTE #2: I haven't used the first board posted in this thread.  So- as to how it sounds, your guess is as good as mine.
Niteshade
    • Niteshade Audio
« Reply #12 on: 10 Mar 2010, 01:26 pm »
NOTE:
Take a look at the Tripath board link in the above post. These things sound GOOD!  :drool:
Has anybody tried this yet? I have and love it. Can't beat the price for what it does.
wushuliu
« Reply #13 on: 10 Mar 2010, 04:44 pm »
NOTE:
I had one for a little while last year. There's a *massive* thread on modding them at diyaudio. It sounded ok stock, but w/ some basic mods (input/output caps and inductors, power supply caps) it becomes a whole new amp. The best combo appears to be the tk2050 w/ those mods powered by a meanwell smps. The meanwell comes to about $50-55 shipped, so tack on $30 for the mods (or higher depending on how boutique you go) w/ the tk and you have an arguable giant killer for $135. Eventually I'll put that combo together and compare w/  my classdaudio amp.
http://cgi.ebay.com/27V-DC-13A-351W-Meanwell-Switching-Power-Supply_W0QQitemZ220566021444QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item335ac26544#ht_2249wt_957
srb
« Reply #14 on: 10 Mar 2010, 05:08 pm »
They also have a 4-channel version (4 X TP2050) which has a finned heat sink and NO FAN.
http://cgi.ebay.com/4-100-watt-4ohm-TK2050-D-class-Audio-Amplifier-Board_W0QQitemZ350326577199QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item519117582f
Then there is a 2-channel version of the 4-channel board, which for some reason still has the 4 RCA input jacks installed, but only 2 of the 4 - TP2050 installed.
http://cgi.ebay.com/2-100W-4-TK2050-Class-D-Audio-Amplifier-Board-New_W0QQitemZ250591914429QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3a587129bd
