tolerable DC offset level for OB 5
0 Members and 1 Guest are viewing this topic. Read 1201 times.
kp93300
« on: 8 Mar 2010, 04:30 am »
I build a preamp  recently and unable to trim the dc offset to zero and this result in a dc offset of  0.1 v dc at the preamp output and a dc offset of  0.7 v at the amplifier output.
i tried it on test speaker without problem.
Is this level of DC offset acceptable for OB5 ?
thanks and cheers
kp93300
jdbrian
Re: tolerable DC offset level for OB 5
« Reply #1 on: 8 Mar 2010, 10:56 am »
Hi
  IMO .7v is way too high. Normally you would try to be under 25mv. You say you have .1v out of the preamp . Does your Power Amp  have a gain of only 7? You need to use a coupling cap. or deal with the problem causing the offset.
   I don't know what the crossover looks like in your speakers but if the bass drivers are DC coupled (no series cap.) then there would be a current of something like .7v/6ohms(DCR) or .117A for a typical 8 ohm speaker which is not good IMO.
Brian
kp93300
« Reply #2 on: 8 Mar 2010, 01:22 pm »
I check . The lower woofers are  dc coupled .
I will try to rectify the problem at the pre.
thanks
kp93300
Danny Richie
« Reply #3 on: 8 Mar 2010, 03:26 pm »
It sounds like you definitely will need some coupling caps on the output.
