tech sheet for ONE.2
0 Members and 2 Guests are viewing this topic. Read 2598 times.
danieljtb
« on: 7 Mar 2010, 10:16 pm »
Hi all  enjoying my burn in time with my new amp.  Is there a tech sheet on this amp or some elsewhere info for us newbies to Virtue amps
stuff I'd like to know:
-is there a fuse inside and what type.
-if so, does the volume knob just pull off so one can unscrew the shell. does the fuse orientate in a certain way
-what are the specs on the power cord tip that goes into the amp.( for if someone wants to use a different psu.  I can measure the OD on the tip, but not the ID.  I assume that the standard psu tells if the tip is a positive or negative center
thanks Daniel
classicjt2
Re: tech sheet for ONE.2
« Reply #1 on: 8 Mar 2010, 01:56 am »
Daniel-
I'm glad you're enjoying your Virtue One.2- it's a great sounding amp.
Owner's manual is here:
http://www.wihifi.com/virtuemanual/Virtue%20ONE-TWO%20User%20Manual.pdf
and will provide most of your answers.
DC plug is 5.5mm outer, 2.2 inner.
James
danieljtb
« Reply #2 on: 8 Mar 2010, 03:41 am »
hey thanks James   that helps a lot   Daniel
virtue
  • Making audio lovers audiophiles
    • Virtue Audio
« Reply #3 on: 10 Mar 2010, 08:01 am »
Thanks, James!  The plug is 2.1mm ID, 5.5mm OD.  I'll update the manual as soon as I get back from my business travels (not Virtue) and have an amp in my own sweaty hands!  Until Marcel tells me that all the orders are filled I refuse to take one myself.  Hope you're all lovin' the high-current love!
