How can I rip a 20bit disc?
0 Members and 1 Guest are viewing this topic. Read 1103 times.
sammie
« on: 6 Mar 2010, 10:24 pm »
I recently picked up a Sony classics disc that is recored in 20bit format as opposed to typical 16bit.  So I have XLD, MAX, and good ole' Itunes to rip.  But the only program that gives me a choice is MAX.  MAX only allows for 16bit or 24bit selection.  Should I choose 24bit?  What will happen if I choose 16bit?  Will it sound worse?  Suggestions?
srb
Re: How can I rip a 20bit disc?
« Reply #1 on: 6 Mar 2010, 10:33 pm »
Is it a "CD" that plays back on a regular CD Player, in other words not some kind of SACD or DVD-A disc?  If so, then it is probably a 20 bit recording that was mastered to the CD in standard 16-bit/44.1KHz Redbook format.
Russell Dawkins
« Reply #2 on: 6 Mar 2010, 10:47 pm »
Yes, "20 bit" is one of many ways recording companies used to (they don't bother much anymore) claim superiority so they could add apparent value and charge more, or encourage you to replace what you already have with something "better".
Most in the trade think that higher sampling rate is more important than longer word length if sound is the issue. Long word lengths are handy when recording because you don't have to watch your levels so carefully.
These days almost all recordings are done at higher resolutions - 24/96 is common and even 24/192 is fairly common. High resolution is maintained through the whole mixing process to the last step where the data is converted (using dithering) to 16 bits and 44.1 kHz for the CD master. All CDs are 16/44.
The only significant quality alternative within the 16/44 format  is the relatively rare HDCD. Rare because the encoders are rare and expensive and come from only one source, as far as I know - Pacific Microsonics.
http://www.stereophile.com/news/10674/
Short answer: all CD players output 16/44.
