0 Members and 1 Guest are viewing this topic. Read 5356 times.
Ed: Just don't be in a rush to set it up. Read the directions a couple of times before you start. Cheers Charlie
Those that use WAV can tell you better, but offhand I'm not sure how the squeezebox software would read it. I suspect your display would show a bunch of meaningless TRACK01, TRACK02, etc.
Bryan,In the file naming scheme you have listed, is this the regular Windows folder structure or is this for the tags?I just preordered a Touch and need to really start learning about the ins and outs of hard drive storage.My preference is to store WAV and not FLAC, but I'm not sure if the FLAC tagging offers a significant benefit that would outweigh my desire to WAV?(New to this so use small words)OP- are you ripping WAV, FLAC etc?Thanks-Mike
With Squeezebox (the hardware) and Squeezebox Server (the software) there's very little reason to use WAV files. You can easily change a simple setting on the server so that FLAC files are decoded on the server and streamed as PCM. This gives you the same net results - you're streaming and playing back PCM on the Squeezebox itself.
