Software question-does this exist?
0 Members and 1 Guest are viewing this topic. Read 1331 times.
Thump553
« on: 4 Mar 2010, 07:24 pm »
I'm looking for software that will load music files (mostly flac, some mp3) from a large playlist (scattered over many directories) and then convert the files to normalized mp3s in a different directory (preserving the originals unmodified).
I can do this in two stages if need be (conversion then normalization) but reading the files from a playlist is essential.
Any ideas?
quietdragon
Re: Software question-does this exist?
« Reply #1 on: 4 Mar 2010, 07:34 pm »
Any ideas?
I do something like this. I split my audio library into two:
  • Reference in /audio/library/
  • Transcoded to MP3 for car and mobile use in /audio/car
I mostly use Robin Bowe's FLAC to MP3 conversion script but customised for my own needs:
  • Non-Latin text conversion
  • Volume normalisation
For my needs, I don't bother with a playlist. I just convert the entire library since disk space is relatively cheap, and the converter is smart enough to only convert new and changed material.
Thump553
« Reply #2 on: 4 Mar 2010, 07:45 pm »
I don't want to convert everything, the library is gigantic and the playlists themselves are pretty big (50-100 tracks each from the same number of artists/albums).
ted_b
« Reply #3 on: 4 Mar 2010, 08:13 pm »
DBPoweramp's batch converter will allow for bit rate, file type and folder filters across multiple directories...but I don't think it will read playlist (text) files and try to find files that way. ?
JRace
  • Greetings one and Everyone!
« Reply #4 on: 4 Mar 2010, 08:31 pm »
I believe Foobar does this.
Have you ever used foobar? If not it can be a initially daunting and confusing task as the software is completely user configured.
jopagi
« Reply #5 on: 4 Mar 2010, 08:46 pm »
MediaMonkey's pretty good about converting from different formats.
MM provides a lot of flexibility on where to put the converted file, and you can set up rules for criteria on how to convert -- what bitrates to use, etc.   You can level the volume during conversion if you like.
It doesn't have a built-in way to do this in a batch script if that's what you're looking for, though, but it does do the conversion in a background process so you could have multiple playlists being converted at the same time if you wish.
Thump553
« Reply #6 on: 4 Mar 2010, 11:51 pm »
Thanks for the tips.  I probably end up using Foobar.  It's funny, I've used it for probably hundreds of hours of playback and didn't have the slighest idea it had that capability.
