0 Members and 1 Guest are viewing this topic. Read 5538 times.
I know others will probably disagree but I would focus on using treatment for early reflection and reverberation time control (the ceiling being a good place where you can put a lot without it becoming visually intrusive). These selfsame treatments can also provide useful bass trapping if used in 3" or 4" depths.You need quite a few bass traps to make a worthwhile difference (although every little helps). Getting good bass is very speaker and listener position related. Put them somewhere bad (like having your listening position in the center of a room) and you are going to be chasing your tail with bass trapping.
Uhhh are you talking about bass trapping to improve sound, or to avoid complaints from your neighbors?What are your speakers? Subs?OB subs are less prone to 'room shaking', but still providing an satisfying experience for the listener, at least in my limited experience. But any significant bass will still leak out of the room. This pretty much the only reason I'm glad I my own place, now that the idea of property as an investment has been shot to hell.I'm a convert to the idea that multiple subs can smooth out bass response. Doesn't mean there isn't a need for traps, but can perhaps reduce the number needed.
Hello all - well, I've finally decided to update the system, and after putting in a reasonable investment in electronics and speakers, I'm now left with room acoustics. Unfortunately, I live in an apartment (can't quite find the right house where I want it...), so space becomes a premium (with all of my crap ). I'm mainly going to be doing bass trapping, and was wondering how much you have to have at a minimum before it becomes effective. The main living area is 14' x 24' x 9' tall. Because of sliding glass doors leading to the patio, the system is oriented across the short axis of the room. I can only add bass traps to 3 corners of the room, as one corner has a door that leads to the garage. I would post pics, but the place is a disaster Will trapping only three corner floor to ceiling be worthwhile? I am debating the GIK tricorners vs 244 panels straddling the corners (mainly because of the cost differential to be honest). P.S. What software do you recommend for being able to show the room layout (walls, openings, furniture, crap)?
Hi polarbare,The formula for figuring out how thick the absorber has to be is:AbsorberThickness Formula: 1130/ (4 x First Null frequency)Example:For 250 Hz absorption:1130 / (4 x 250) = 1.13 ft thick.james tannerBryston
That formula finds the quarter wavelength of the given frequency which is the 'optimal' thickness. Treatments MUCH thinner than that will have an impact at 250Hz or lower.Bryan
