Replacement PS caps
0 Members and 1 Guest are viewing this topic. Read 1201 times.
richidoo
Replacement PS caps
« on: 4 Mar 2010, 06:42 pm »
My Netgear ReadyNAS NV powersupply blew 3 electrolytic smoothing caps. It is a common failure for this nas. The stock caps are chinese brand I never heard of before. The caps are an odd size so I can't find them at the normal sources, digikey, mouser, etc.
Does anyone know where I can buy 2200uF, 10V, 105C, 8mm x 25mm aluminum can electrolytic caps?
10mm wide caps will not fit, it's very tight.
Thanks for any help!
Rich
sts9fan
Re: Replacement PS caps
« Reply #1 on: 4 Mar 2010, 06:44 pm »
Digikey or mouser will hook you up.
srb
« Reply #2 on: 4 Mar 2010, 06:56 pm »
sts9fan
« Reply #3 on: 4 Mar 2010, 07:00 pm »
Guess I should read better.... :duh:
richidoo
« Reply #4 on: 4 Mar 2010, 09:27 pm »
That's OK sts. Thanks anyway. I wish they did, I could put in some nice nichicons.
The brand of caps that failed is called Fuhjyyu, made in Taiwan. They are a problem in a lot of computer and consumer gear that fell for the low price. They stole the electrolyte formula from a Japanese mfg but didn't get it right.
EDIT: I ordered a replacement power supply for 100 bucks. Hopefully it uses better quality caps this time.
Rich
