power on pop noise
0 Members and 1 Guest are viewing this topic. Read 1357 times.
Robin
power on pop noise
« on: 4 Mar 2010, 03:05 pm »
Recently, my RM-5 II makes pop noise when RM-5 II recovers from power on mute. And at a phono position, a speaker cone moves backwards and forwards as I turn volume from left to right and from right to left.
After some turning volume from left to right and from right to left, the speaker cone did not move.
I wonder that coupling capacitors leak current shortly after power on.
Does someone know a symptom like this?
gerald porzio
Re: power on pop noise
« Reply #1 on: 4 Mar 2010, 03:19 pm »
This sympton is older than you. A cap needs replacement & you might need a subsonic filter to deal w/ the phono/woofer issue.
Roger A. Modjeski
« Reply #2 on: 4 Mar 2010, 09:53 pm »
I'm not quite sure I understand the part about turning the volume control. As to the pop it could be a leaky cap but I have never replaced one yet. They are very good.
If you are saying the woofer continues to move at moderate volumes after the first few minutes that indicates a loss of power supply regulation.  That would also explain the pop at turn on.
