0 Members and 1 Guest are viewing this topic. Read 10689 times.
I really think you have to consider speakers and power amps together. I just can't think of suggesting amp without knowing what kind of speakers you will be driving with the amp.
not trying to fix anything i love the way may system sounds with my HT3 speakers.just for a future system and i'm thinking that tubes for a power amp should sound better otherwise it would seem like a lot of hassle to change power tubes all the time with little benefit and a little dangerous maybe with little kids in the house. it would be in a small room with maybe some deadalus high efficiency speakers.
To all involved in this thread,Earlier this morning I attempted to split and move a post to the IGWB and thoroughly botched it.The post in question was Wayner's plug for the new Van Alstine Ultravalve amp. During the removal process I clicked the wrong link and got lost in a digital vortex resulting in my not having an explanation placed where the original post was and I lost the original as well.I begged for mercy and MaxCast was kind enough to find it and put in the bin but along with it went my explanation that I posted separately which ended up at the end of the thread like any other normal post does.Apologies to you members, Wayner, and AVA.Although I haven't heard an Ultravalve with my own ears the OP should still have it on his list of amps to check out. From the reports it definitely would be on my radar if I were looking for a tube amp fitting the requirements that stump4545 gave us. It would be nice if an Ultravalve owner would pipe up in this thread with their two cents worth on it.Thank you,Jake
Everything is cool, and thank you Jake for pointing out my erroneous post as it is not allowed for MFGRs to post in these types of circles. Wayner
Any idea how the Joule-Electra Stargate monoblocks might match up with those Daedalus speakers?
Last year at RMAF, during after hours listening, a pair of Quicksilver mono-blocks and a pair of Atma-Sphere M-60 mono-blocks were auditioned in the Daedalus Audio suite with the Ulysses speakers. There was a compatibility problem with the Quicksilver amps. Hum and noise and just not being very happy. The Atma-Sphere amps were a wonderful match-up. The room was a bit too large for this to be perfect, but in a smaller room, I could see these being a great combo.The Ulysses were used with mono'ed ModWright amps during the day. The ModWrights were a better choice for full dynamics and extended low end in the large room. The Atma-Spheres did give off a more "holographic" image. The high end was also "sweeter" with the tubes.There are rumblings that a larger pair of Atma-spheres might find their way into the Daedalus room this year at RMAF.Lou has discussed sending out a pair of DA-RMa to Denver for break-in and evaluation prior to RMAF. If that comes about, I will try to make sure various Denver audiophiles will get a chance to listen to the speakers with their favorite tube amps. These can range from Jason's (Pez) 15 watt SimpleSE, through Tyson's modded out Stereo 70s to whatever Mike Galusha is using presently. I believe he still has a modded McIntosh MC275 IV and a pair of modded Consonance Cyber 845 single ended amps. There are also some ModWright amps that can be used to compare and contrast SS vs tube on these speakers.
any suggestions for an id integrated tube pre amp/amp?
What's an "id integrated"??
