Anybody here running a Linux virtual machine on their Mac?
0 Members and 1 Guest are viewing this topic. Read 1120 times.
dB Cooper
Been playing a with it a bit just for grins, but cannot get it to recognize my laptop display- it only gives me 800x600 or 640x480 options, even in fullscreen. I am using Mint 8 (Ubuntu-based) and have tried it in both Parallels 5 and VirtualBox with the exact same behavior. Thanks.
Doublej
Re: Anybody here running a Linux virtual machine on their Mac?
« Reply #1 on: 3 Mar 2010, 07:05 pm »
I have both Ubuntu and Fedora running under VirtualBox. Currently I have no problems with resolution but had in the past with an previous version of Ubuntu.
If my memory serves me correctly when I encountered the problem and Googled it, I found it was a known limitation at the time.
I think you need to install Virtual Box Guest Additions to enable higher resolution. The thread below may provide value to you.
http://forum.linuxmint.com/viewtopic.php?f=90&p=149265&st=0&sk=t&sd=a
« Last Edit: 4 Mar 2010, 12:07 am by Doublej »
skunark
« Reply #2 on: 4 Mar 2010, 03:28 am »
You can also do a VNC session.
