Cartridge Recommendations for a Modded AR XA turntable
0 Members and 1 Guest are viewing this topic. Read 2858 times.
Funnehaha
This is my first post.
I'm modifying an AR XA turntable with a new Rega RB301 tonearm [yet to be purchased, but the modified subchassis and top plate is set up for it] and
would like some recommendations for cartridges that might be suitable.
MM or MC? I haven't decided yet...
Wayner
Re: Cartridge Recommendations for a Modded AR XA turntable
« Reply #1 on: 3 Mar 2010, 04:32 pm »
So the Rega arm is mounted to the sub-chassis (as it should be)?
Wayner  :D
Funnehaha
« Reply #2 on: 3 Mar 2010, 04:50 pm »
Hi Wayner,
  Again, I haven't bought the RB301 yet, but I'm planning to attach it to the subchassis when I do. I usually go to the Needle Doctor or HiFi Sound for cartridges.
Wayner
« Reply #3 on: 3 Mar 2010, 08:21 pm »
The new Rega RB301 arm does not come with the former 1/2" threaded pipe mount, which may have been easier to adapt to your AR, but rather now has 3 screw points on a rather large bolt circle. It will present you with some challanges, but hopefully, you can get thru it. It should sound real good if you can get by the monkey work.
Wayner
Funnehaha
« Reply #4 on: 4 Mar 2010, 12:51 am »
Hi Wayner,
  Yes, the modded subchassis has the three mounting holes needed for the RB301. Besides cartridges, it would also be cool to hear any
recommendations concerning the motor, pulley, etc. anyone has.
Thanks.
mjcmt
« Reply #5 on: 12 Mar 2010, 01:25 am »
The Ortofon OM10 thru OM40 are nice high compliance cartridges. Very dynamic and clear.
Also consider the Ortofon 2Ms. A step up from the OMs.
AudioSoul
« Reply #6 on: 12 Mar 2010, 05:09 am »
   How much can you spend on a new cart? What are your expectations sound wise of your new cart. If you want a moving coil sound without a stepup transformer lots of folks like the Denon DL-160 for instance $180.00........ :thumb:
jimdgoulding
« Reply #7 on: 12 Mar 2010, 05:17 am »
Wow.  Nice project.  I don't have a cartridge rec.  I'll defer to Soul, Wayner and Mjc.  Just wanted to say hey, onward and upward!
