Bryston 4bsst2 power
0 Members and 1 Guest are viewing this topic. Read 2539 times.
Cwlam3
« on: 3 Mar 2010, 01:13 am »
  I have a pair of Mirage M3si speakers, they are 6 ohm speakers.  Do you think a 4bsst would have enought power for them.  Thanks.
VOLKS
Re: Bryston 4bsst2 power
« Reply #1 on: 3 Mar 2010, 02:32 am »
Very easily enough power indeed.Friend of mine has your speakers and i hooked up my 4BSST2  to them and there was no issue at all about more power needed.Also sounded very open...decent midrange,but the sweet spot can be tricky to find with those speakers.
Cwlam3
« Reply #2 on: 3 Mar 2010, 03:42 am »
Hi Volks,
  I know what you meant.  The speakers are not perfect but not easy to get rid of  because of the size.   Do you think a Bat V5SE tube pre-amp would match well with Bryston ?  Thanks. Eddy
VOLKS
« Reply #3 on: 3 Mar 2010, 04:31 am »
Hi Volks,
I am sure it would be ok,but personally i find most tube pre-amps actually ``Colour`` the sound of the music  and that is totally opposite of what a Bryston Pre Amp does or any Bryston product......Bryston is very Neutral and adds nothing to the original recording in the way of colour......unlike ``some`` tube amps...tube preamps
