Audio/Video Gear and Systems
Owner's Circles
Niteshade Audio
Niteshade preamp with ClassD amp
0 Members and 1 Guest are viewing this topic. Read 1671 times.
roymail
Roy in TX
1 Mar 2010, 10:42 pm »
Blair, could you give us your impressions of using either the Beacon 1 or 2 with the ClassD audio amp?
Also, while you're at it, how well does it work with a passive?
pardales
Re: Niteshade preamp with ClassD amp
1 Mar 2010, 11:23 pm »
I was wondering the same things.
Niteshade
Tubes: Audio's glow plug. Get turbocharged!
Reply #2 on:
2 Mar 2010, 02:57 am »
I can make a low gain Beacon One or Two for a Class D.
These preamps can have a gain selector installed as well: Unity (0) and amplified (18db or there about).
Owner's Circles
Niteshade Audio
