When is the power really on?
0 Members and 1 Guest are viewing this topic. Read 1304 times.
jaxwired
« on: 1 Mar 2010, 10:23 am »
I thought I knew the obvious answer to this question, but a debate on a different forum has prompted me to post this question here.
My Bryston 2bSST2 has a mains power switch on the back and the push button power switch on the front.  Obviously if I have both off, then it's drawing zero power.  However, to keep the amp warm and fully ready for optimum performance, I leave the back mains power switch on all the time.  My question is, do I need the front panel power button on all the time also?  I thought the obvious answer was yes, but some people seem to think that as along as the back panel power button is on it's fully juiced.
95Dyna
Re: When is the power really on?
« Reply #1 on: 1 Mar 2010, 01:41 pm »
Hi Jaxwired,
When the front switch is off and the rear switch on on my 7B SST2's the amps are stone cold to the touch.  When both are on the amp is moderately warm to the touch.  I don't know if the 2B is different in some way but can't imagine why it would be.
Bill
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 1 Mar 2010, 11:55 pm »
Sorry I just noticed this - if the circuit breaker switch is "ON" and the Power switch on the front is "OFF" there are a few milliamps still going into the amp to allow for the 12 volt trigger turn-on circuit to activate if required.
james
Stu Pitt
« Reply #3 on: 2 Mar 2010, 04:25 am »
There are a lot of products that draw power even when turned off.  I read somewhere that the XBox 360 costs about $100 or so per year in electricity if plugged in but never turned on.  The PS3 was even more.
Just makes you think...
