0 Members and 1 Guest are viewing this topic. Read 3927 times.
When I do that will I just need to change where the files are ripped to under the Preferences option? When files are now being ripped to the external HD will all of the files located in both places, internal and external, be seen together when viewing the iTunes art for music selection?
I guess what I am asking is that doing this, is it different than creating a new Library? And if I had created a new Library, not that I fully understand how, is that when the files actually would become separate from each other and not be viewed together?
With an external HD connected by firewire will it be continuously active as a spinning drive, or just when selected to play music?
I will share my setup - Mac Mini AIFF content; stored on an iOmega Minimax 1TB external hard drive (Firewire). I have a second iOmega with all of the files backed up, sitting dormant.
I have read that this HD can be noisy. Can you hear it?
The reason I was considering Firewire is that my DAC is USB and I understood it best to separate the external HD from also sharing the USB if possible.
Could you explain to me a little about Timemachine and how I should use it to my advantage? I assume this does auto back-ups? Where would these files get stored, on a second external HD? If so and if I use Firewire, can one drive be connected in series to another?
I"ll say it again for backups:http://www.shirt-pocket.com/SuperDuper/SuperDuperDescription.html
