7BSST2 vs 14BSST2 with new transformers
0 Members and 1 Guest are viewing this topic. Read 2726 times.
Fullvolume
« on: 25 Feb 2010, 04:39 pm »
In considering in purchasing a 2x7B or a 14B, I searched for pros/cons.
I found this:
There would be 2 advantages to a 7B over a 14B.
The 7B being Mono allows you to place the amplifier very close to each speaker - always a good idea-- and the 7B has twice the capacitance in the power supply section over the 14B.
Other than that they are identical.
My question is: Does the new transformer change the above advantage?
  • The Demo is Everything!
    • http://www.bryston.com
Re: 7BSST2 vs 14BSST2 with new transformers
« Reply #1 on: 25 Feb 2010, 04:42 pm »
Hi,
Yes it still applies.
james
95Dyna
« Reply #2 on: 25 Feb 2010, 10:04 pm »
Hi Fullvolume,
Last year I did what you are now doing after deciding on Bryston from a couple other brands.  I went back and forth on the 14 or the 7's always leaning toward the 7's.  When I discovered this power supply capacitance advantage for the 7B's that's when I made the decision to go with the 7's figuring that more than justified the extra $400.00 or so.  I lucked out and bought SN's 1850 and 51 and the cutoff for the new transformer and capacitors is 1825.  Best wishes making your decision and don't torture yourself too long! :D
Bill
werd
« Reply #3 on: 25 Feb 2010, 11:31 pm »
Hi Fullvolume,
Bill
hello
The new transformers in 7 or 14B may reduce the demand on large capacitors. Narrowing the difference between the two.
