Ripper heat sinks
0 Members and 1 Guest are viewing this topic. Read 1625 times.
Fredo
Ripper heat sinks
« on: 25 Feb 2010, 03:15 am »
I'm collecting parts for a Ripper half kit, but I can't find the heat sinks at Digi-Key, no records match the search criteria. Any suggestion for a suitable heat sink?
http://search.digikey.com/scripts/DkSearch/dksus.dll?vendor=0&keywords=HS224
Thanks in advance,
jules
Re: Ripper heat sinks
« Reply #1 on: 25 Feb 2010, 03:58 am »
http://www.conradheatsinks.com/welcome.htm
Conrad heat sinks in Australia. They seem to be used world wide and there's quite a choice
jules
Fredo
« Reply #2 on: 25 Feb 2010, 11:51 pm »
Hi, Jules,
I'll try to buy all parts from the same supplier, the problem is there is no heat sink at Digi-Key with the part number indicated in the ripper kit manual (HS224). Possibly it's a discontinued item, I don't know.
Thank you anyway!
Best regards,
jules
« Reply #3 on: 26 Feb 2010, 12:32 am »
Hi Fredo,
so it's a small sink for a specific purpose. If you don't get an answer here maybe you need to send an email to Hagerman.
If you've got a photo it might be possible to get some suggestions for an alternative.
jules
schubert
  • I'm the one on the right
« Reply #4 on: 26 Feb 2010, 04:51 pm »
I ran into the same problem, so I just ordered the same one used in the chime (HS372-ND) - it has the same footprint, and if it's too tall I'll just cut it off with a hacksaw.
Fredo
« Reply #5 on: 27 Feb 2010, 05:24 pm »
Added to my bill of materials.
Thank you, schubert!
schubert
« Reply #6 on: 20 Mar 2010, 06:25 pm »
For the record - HS372-ND fits just fine.
