Which AV Connector Does Playstation PS3 Use?
0 Members and 1 Guest are viewing this topic. Read 1540 times.
NagysAudio
    • http://www.nagysaudio.com
« on: 24 Feb 2010, 07:08 pm »
I'm interested in knowing the correct name for this connector and if any suppliers sell it.
srb
Re: Which AV Connector Does Playstation PS3 Use?
« Reply #1 on: 24 Feb 2010, 07:39 pm »
It is proprietary to Sony and simply called "Multi AV".  Since there are HDMI and Toslink optical outputs for digital video and digital audio, it is only needed for analog video and analog audio output.  You can either get a Component Video or S-Video version.
Monoprice sells them for < $5.00
Multi AV - Component
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10830&cs_id=1083003&p_id=4009&seq=1&format=2
Multi AV - S-Video
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10830&cs_id=1083003&p_id=4008&seq=1&format=2
If you are looking for the connector only, then you can try to search on "Sony PS3 Multi AV".  It may be hard to find, but obviously other manufacturers are sourcing it somewhere.  Since you apparently make cables, you are probably just looking for the connector, but as each new day further obsoletes analog connections, I'm not sure why you may want to pursue a search.
NagysAudio
« Reply #2 on: 24 Feb 2010, 07:48 pm »
Hi srb,
Thanks for your reply. Are you certain that this connector is proprietary to Sony? Basically what I'm looking for is a source who would sell the connector only, I need a high quality one with silver/gold contacts that can be soldered, teflon dielectric, etc.
srb
« Reply #3 on: 24 Feb 2010, 07:59 pm »
I guess it's possible it exists under another name, but I always thought it was proprietary to Sony, and have never heard a reference to another name for the port.
Here is a link to a pinout of the connector.  They reference it as "Sony PlayStation Videogame and some other devices", but I don't know if "some other devices" is referring to other Sony devices or not.
http://pinouts.ru/Home/PlayStationAV_pinout.shtml
If you could find a source, it's doubtful that there would be a high-quality version of it available, just not enough demand for that sort of thing.  Sorry, that's all I have.
